Tiling a shower ceiling
SVH | Posted in Construction Techniques on April 8, 2008 04:23am
Does any body have any advice on what to set tiles on the ceiling with?  I have installed ½â€ Hardie backer and put about a 100 screws in it.  Any advice would help.
SVH
  1. sharpblade | Apr 08, 2008 05:49am | #1
    the usual latex modified thinset will do. Once pressed in hard, the air/barometric pressure will hold the tiles up till set. (have you ever tried prying a tile from a floor after it's been firmly pressed down??)
    Wear goggles/eye protection while doing it, also when grouting. Getting the stuff in your eyes is no fun. DAMHIKT.
    1. SVH | Apr 12, 2008 04:52am | #8
      I put the tile up tonight with out any problems.  Thanks for the input.  I can't seam to figure out how to post to everyone so thanks to everone that helped.
      SVH
      1. Jim_Allen | Apr 12, 2008 04:58am | #9
        When you hit "reply", open the dialogue box next to the word To: You'll see the choice "All". Bob's next test date: 12/10/07
        1. Jim_Allen | Apr 12, 2008 04:58am | #10
          See, I replied to "All". Bob's next test date: 12/10/07
  2. FastEddie | Apr 08, 2008 05:54am | #2
    With properly mixed thinset, tiles up to about 6x6 will easily stay in place.  When you grout, keep your mouth closed.  Don't ask how I know.
    JeffBuck | Apr 08, 2008 06:14am | #3
    the right mix with any modified thinset along with the right trowel size will work.
    but for bigger tiles I like the extra security of a thinset with extra "stick"
    I prefer Mapei UltraLite ...
    and I know Custom makes one too, can't think of the exact name.
    UltraLite is pricey ... but has great initial stick.
    for bigger tiles I used to do the ceiling first, and run a ledger around the walls about an inch and a half down from the ceiling ... the run 1x strapping across when all done and shim up tight ... just to keep things from moving overnite.
    don't bother now with the UltraLite ... just stick it once and it's stuck.
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
    1. FastEddie | Apr 09, 2008 01:00am | #4
      Is Ultralite the right name?  I have used a Mapei product called Ultracontact.  very sticky."Put your creed in your deed."   Emerson
        JeffBuck | Apr 09, 2008 02:15am | #5
        http://www.mapei.it/referenze/Multimedia/UltraliteMortar_TDS_E.pdf
        found trying for a pic of the bag.
        Jeff    Buck Construction
             Pittsburgh Pa
        1. FastEddie | Apr 09, 2008 02:26am | #6
          I'll see your Ultralite and raise you a bag of Ultracontact ...
          Data sheet
          English
          French
          Spanish
          Material Safety Data Sheet
          English
          Ultra Premium, Full-Contact Mortar
          Ultracontact is an ultra premium, normal-setting, polymer-modified, high-performance full-contact mortar. Ultracontact meets or exceeds ANSI A118.4 and ANSI A118.11 requirements when mixed with water.
            JeffBuck | Apr 09, 2008 02:35am | #7
            I've used the UltraContact too.
            also their rapid set version for some big tiles on a big floor we wanted to be sure we could fully grout the next morning. Had hoped of grouting that night but reality set in.
            but I like the fluffy-ness of the Lite.
            trowels real nice ... and great initial stick.
                 Buck Construction
                 Pittsburgh Pa
  4. IdahoDon | Apr 12, 2008 05:15am | #11
    How'd it turn out?
