tiling exterior steps
woodenhead | Posted in Construction Techniques on January 25, 2005 04:52am
I would like to tile the entrance to my house; it consist of four concrete steps. What type of tile is best,and how do i go about doing a quality job.
  1. davidmeiland | Jan 25, 2005 05:05pm | #1
    The simplest project for a first-timer would be a simple countertop or interior floor.
    I suggest you buy and read Michael Byrne's book 'Setting Tile'
      woodenhead | Jan 25, 2005 05:25pm | #2
      I have tiled my own bathrooms,what i would like to know is there different materials involved when it is an exterior project
  2. jrnbj | Jan 26, 2005 08:08am | #3
    Just my personal opinion but I'd do almost anything except tile for a front step....new concrete, brick, slate, bluestone etc....if you are determined to tile then your concerns in order of impotance would be 1) specify a tile acceptable for exterior use & for floors (i.e. "non slip"), 2)specify the right mortar & grout 3) make sure your existing steps provide a decent substrate & plan how to incorporate the extra ~1/2" into existing trim thresholds etc.
    EricPaulson | Jan 26, 2005 09:33pm | #4
    try over here
    John Bridge Services
    http://www.johnbridge.com/
  4. cliffy | Jan 26, 2005 10:22pm | #5
    Hello King of Beers!
    I tiled my mother's front concrete landing and step a few years ago and it went well.  We have 5 or 6 months of winter here so if that is a concern for you you should get a "frost proof" tile, a porcelin tile.  You may recognize it by the colour going all the way through unlike a ceramic tile whose surface is baked on clay.  I used thin set mortar ( probably versa bond if I remember correctly) with a notche trowel and grouted the next day.  Make sure you pick a tile with a rough texture so you don't fall on yer but too often.  I used the same kind of tiles for showers at my old job and the held up well in a government facility that was close down for the winter and left un heated.
    Get yourself a box  of disposable gloves for plying with thinset and especially the grout.
    Have a good day!
    Cliffy
      woodenhead | Jan 26, 2005 10:38pm | #6
      Thanks for the advise.
  5. FastEddie1 | Jan 27, 2005 02:50am | #7
    Sounds like a reasonable project.  As noted, safety is a big issue, and you need frost proof tiles.  Talk to a tile store and they can show you which tiles are suitable.  Hoaw are you going to treat the riser of the steps?  And the edge of the tile?
Picture-Perfect Pergola
