I need to install a new tile kitehen countertop. The old top is white corian. Is it possible to tile over the corian without installing cement board over it? If so would the modified thinset work. I’m going to install granite tile over it.
Why not refinish the corian? Its not that hard to do. I would liquid nails 1/4" backet to the tops before the tile if you must cover the corian.
The corian is cracked at the corners and it looks ugly! I guess the guy who installed it years ago didn't fit it right. Why the airspace between the corian and the new tile?
Jim
Jim,The cracks in the Corian could doom any tiles directly set to the Corian. Solid surface moves too much for large format tiles. I think you risk either cracking or popping off when the Corian moves.Bill
Thanks for the help. The majority of the replies said to remove the corian or at least put backer over it. What do you think about installing 1/4" backer over the corian with construction adhesive instead of thinset. Construction adhesive is pretty stick stuff.
Jim
jim,What you propose might work. I just don't know. I agree with the others who recommend either repairing the Corian that is there, or tear it off and build a substrate of proven stability. Redoing it is so easy, why gamble with unknown issues?Bill
Airspace? i meant hardi backer to install the tiles on. Corian do make a repair kit for cracks and a good guy could fix it for you. But if its just whit I can understand why the change.
I did a tile inlay with white modified thinset. Sticky stuff. Worked well.
As for a whole top? Beats me, but I guess it would work.
Quittin' Time
You should call the manufacturer of the thinset you want to use and see if they will approve thinsetting to Corian. My guess is that they will not, and that you should remove the Corian, install new plywood subtops if needed, install cement backer board, and then your tile.
Corian's not very porous. Maybe start with a 2 part primer. Ardex P 82 is amazing stuff. Available from serious stone/tile shops for "non-porous substrates". Works with thinset very nicely.
Jim
It cant take you all that much time and money to remove the corian and replace with ply/backerboard and then you'll have no concerns about what may or may not happen down the road.
Why are you making so much work for yourself - and only to get an installation with grout lines (think scum build-up, stainind and clean-up) and tiles whose edges (sink) will need to be polished or otherwise addressed?
Instead, using an orbital sander, refinish the existing countertop. As for the cracks in the corners - get a few joining kits from Corian for the color countertop you have. They have a very short pot life, but if you have your ducks in a row, you can fill in the crack so that they are "good enough."
Much less work than installing CBU and tiles.
Frankie
Experiment with the placing of the ingredients on the plate. Try the mozzarella on the left, the tomato in the middle, the avocado on the right. Have fun. Then decide it goes tomato, mozzarella, avocado. Anything else looks stupid.
Richard E. Grant as Simon Marchmont - Posh Nosh
Thanks, Frankie, sounds like a quick fix for the short run. Then I can decide what to do later.
Jim
