Is there any reliable way to ceramic tile over block walls that have been painted? This is in a basement shower area.
Thanks!
I refuse to accept that there are limitations to what we can accomplish. Pete Draganic
Thanks!
If it were me I'd put up wire and a scratch coat......then the tile...
I just put a call in to the guys at Dal Tile and they say that simply roughing it up with sandpaper (he recommended aluminum oxide on a belt sander) is sufficient to set the tile with thinset.
I did two showers in a public, busy building in 1995. We ran a sand blaster on each side to remove the loose flakes etc. Used versa bond if I remember corectly and it still looks and performs fine.
Have a good day
CLiffy
