I’m considering tiling over the large format wall tile in my bathroom. The present tile has a rougher texture and a matte surface. I was thinking about using thin set for the adhesive. Is this a bad idea?
Listeners write in about saving frogs, attic ductwork, lime wash, and energy ratings for real estate.
I'm not a tiler but I have read that it can be done. The glaze on the tile must be scored with a grinder and you must use modified thinset, not regular thinset (as I recall reading a few years ago). Tiling is not a regulated trade, so the individual skill level is quite variable. Furthermore, any handyman can call himself a tiler when out of work. So for this unusual job, I would suggest doing a lot of reading on the various manufacturer's websites (and watch their videos) about applications/conditions/best practices/installation restrictions and techniques, etc. I specified Mapei products on an unusual tiling job in my own home, and would highly recommend their products. Yes, I spent hours and hours (did I mention hours?) reading and ended up knowing more than most tilers. Google is your friend and good luck.
I've done a lot of tiling, and I would never attempt it. All the time researching, worrying and trying to end up a good result is way longer than getting a hammer and tearing it out. Start with a clean slate.
I've done a lot of tile. Only once have I done tile over tile. I used epoxy thin set.
I've done it and it works just fine. Take a diamond blade on an angle grinder and scuff up the tile a little to give the thinset something to tooth into. You are going to need a new threshold at the door and you will need to plane down the undercut to allow for the height difference. You may need an extra wax ring on the head other than that no big deal.
I did two bathrooms this way 18 years ago and both still look great.
Thanks to all that responded. Steve: I'm only considering this for the walls. I"ve got a lot of wall surface - maybe 200 sq feet. Did you use regular thin set? How much of the tile surface do you estimat tht you scored?
I did not do walls I did floors, but I think you will be okay doing the walls over. What size/format tile do you have on the walls? The smaller sizes have more grout which allows the thinset to bond better. Just make sure to grind something into each tile and you will be okay.
Sawdust_Steve. The walls are a pattern of 12x12, 6x6, and 6x12 tiles.
Give them a good rough up. Or just remove the tile.
