I am about to install 3/8x 12×12 ceramic tile on walls in a bathroom, what should I use to adhere them to the walls, Mortar or the glue type adhesive?
guidance is greatly appreciated!
If they will be in a wet area, like the shower or tub surround, then thinset is definately the way to go. Mastic does not belong in a wet area.
If it is walls in the room like wainscoting, then mastic is ok. Don't use mastic on the floor.
If you are doing a shower or tub surround, I hope you are using something on the walls other than plain sheetrock.
Check out this tile forum johnbridge.com
Thinset mortar for walls.
Nice job.
I also use running bond rather than stacked for most of my stone work.
"A job well done is its own reward. Now would you prefer to make the final payment by cash, check or Master Card?"
12 x 12 on walls means you need the wall plane finished to a perfectly flat surface first. Any irregularities will ruin the job
