tin ceiling install
user-5416640 | Posted in General Discussion on September 13, 2003 10:43am
I’m considering using decorative tin (12″x12″) for the ceiling in my kitchen which is about 16’x8′ and is completely gutted. Has anyone installed this? Does it fasten to a sheetrock ceiling? nailed/screwed? Downfalls? Where to find the product for a fair price? cutting tool for ceiling fixtures? thanks, mark
  1. MisterT | Sep 13, 2003 12:46pm | #1
    Your inspector may want you to put up a layer of DW for fire code, but we just did one over plywood.
    strapping (furring) would work, but you will need to figure out your panel layout ahead of time.
    Get the pre-primed if you are going to paint them.
    Mr T
    Do not try this at home!
  2. Steve1 | Sep 14, 2003 05:12am | #2
    i installed a tin tile ceiling a couple of years ago, i used the decorative nails from the manufacturer and fastened it to a drywall ceiling also using panel adhesive
    i put adhesive in each corner of each tile and in the middle
    cut outs are tricky, i used a diamond blade in a small grinder but any abrasive blade would work, it was what i had available
    only real hint i can offer is start straight and square same as ceramic floor but of course the tiles do overlap
    any other questionss, i may be able to answer, only done it once but no call backs
    Mongo | Sep 14, 2003 08:42am | #3
    Like Mistah Tee, I think it's easier to install over ply.
    Consider drywall for for code, then skin the drywalled ceiling with 1/2" ply. The 4 sheets will be well worth it, as they will allow you to nail the tin anywhere you choose and will give the tin a solid backing. Especially helpful if using tin crown molding, etc. Another option is to strap the ceiling with the strapping on the nail lines. I still think ply is easier.
    Snap chalk lines for layout. Don't forget overlap in your layout lines.
    Use nails from the manufacturer. Small round-headed ones usually.
    Cut with tin snips.
    Have used a hole saw to cut holes, but won't advise it for a newbie. Easy enough to start the hole then finish with snips.
    FHB has tin ads in the mag. Good prices, good service.
    Careful with the fingertips. Easy to get sliced.
    1. MisterT | Sep 14, 2003 01:37pm | #4
      One more advantage to using plywood.
      Any cut-outs for boxes or cans can be laid out and cut into the ply.
      Then when you get to one with the panels use a laminate trimmer with a pilot bit to cut it out.
      I used a router speed control to slow down my lam. trimmer so metal chips weren't comming at me at 100mph.
      And remember there is NO more important rule than to always were these ,__O-O__, safety glasses!!!Mr T
Installing Prefinished Cabinet Molding
Use these assembly techniques when installing crown risers and molding to minimize visible gaps and nail holes.
