Tired of copper pipe sizes
IMERC | Posted in General Discussion on August 9, 2004 12:00pm
Tried the search function to find some of the old threads on cork flooring… Has anyone saved or booked marked them or the prouduct links…
Google was over whelming…
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming….
        WOW!!!   What a Ride!
  1. UncleDunc | Aug 09, 2004 12:18am | #1
    I just entered "cork flooring" (without the quotes) in the search box. The copper pipe thread came up in the message reading frame, but the index frame on the left showed 100 messages containing both cork and flooring. It only displays the copper pipe message because it thinks it has to display some thing while completing the search. If the search really doesn't find what you're looking for, the left hand frame will display "No messages found" or "0 messages found" or something like that.
      IMERC | Aug 09, 2004 12:23am | #2
      I just did it again and the damn thing only gave me CP sizes...
      My dialup transfer rate is + 1KB or so... The webb can be a real chore....
      Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming....        WOW!!!   What a Ride!
      1. UncleDunc | Aug 09, 2004 12:43am | #3
        That's really weird. What does it say in the index frame? If you don't see a line with a magnifying glass and "Search Results", it's not done yet. Right after that you should see either "No matches found" or some number followed by "messages found". How long are you waiting after you see the copper pipes? What are you seeing in the left frame when it looks like the display has stabilized?
        You know, even when it does find something, it doesn't change the message reading frame, at least on my browser. It leaves the copper pipe thread there until I click on one of the messages in the index frame.
        I just tried it again with a search string I know doesn't occur and got the copper pipes on the right followed a short time later by "No matches found" on the left. Tried it a third time and got the same results as my first try, 100 messages found, but the copper pipes thread remains in the message reading frame.
          IMERC | Aug 09, 2004 12:51am | #4
          Doh!!!
          Went for coffee and that made a big difference...
          Give it lots of time and then some more..... I had called it done after I saw the CP thread.....
          Thanks....
