Tired of searching–cedar shingle repair
I love this site but hate the search feature. I KNOW I have seen discussion of how to repair broken cedar shingles in the middle of a wall. The only thread I can find has three posts and requires a tool that is apparently no longer available (roofing iron)
I made the mistake of sending my Dad a picture of the shakes I just installed on my house, and now he wants me to fix his.
If anyone can point me to a thread or tell me how to replace the broken shingles I would really appreciate it!
-Rich
You need a SHINGLE RIPPER (I think that's what they call it).
It's a long flat bar with a hooked end used for pulling nails out behind the shingles.
It's a pain in the #### to get all the nails out. If you only have a few shingles to replace it's not too bad. If you have a high percentage of shingles to replace it's easier to rip them all out.
Thank you! The only term I could find was roofing iron. Found a shingle ripper I can buy with a quick search.Now for installing the new ones...An old post here suggested holding the new shingle out 1/2 inch, driving nails with a 45 deg upward angle, then driving the shingle all the way in. Supposedly this will pull the nails up where they should be and will only require a few taps with a hammer on a flat bar (or the ripper) to fully set the nails. Is this what you do? Are there other/better methods. This repair is on a steep pitched roof (and some sidewall) in a wet climate, so I would prefer to get the nails hidden.-Rich
shingle thief is the eterm
use the shingle theif to pull them out...
only the last course gets nailed with the 45 deg. angle , then drive the butt up, which straightens the nail and hides it under the course aboveMike Smith Rhode Island : Design / Build / Repair / Restore
Thanks, everyone. Sounds like the upward driven nails is the answer. We'll give it a shot.-Rich
It may be the one you've already found, but Harbor Freight sells a shingle ripper for not much money. I bought one a few years ago to replace some shingles on my house and it worked well enough.
