Lumber yard rep is pushing it like mad. The literature was very convincing, but I would like to hear an opinion of an actual user.
thanks
Derek
FHB Podcast team chats about adding Larsen trusses to an existing stud-frame home with no additional sheathing.
Video: Build a Fireplace, Brick by BrickRelated Stories
the big advantage is that it is a PERMANENT hot melt glue, not a temporary glue used for clamping and holding while other glue(white, yellow,etc) dries. it can be used to reduce or eliminate fasteners in some applications.
*Sounds interesting, I haven't seen, or heard of one before. I have used the Loctite reactive urethane hot gun, but it's a very expensive toy.
*I've been using one since December. It's been working great, however the glue is a little pricy. As an experiment, I glued two 6" by 3" pieces of 3/4" MDF using a butt joint. Nobody was able to break them apart after 24 hours. That sold me! Doug
*Recently spoke with a cabinetmaker buddy who said that the stuff is being used to put together face frames without pocket screws now.........
*Sounds like 3M's Jet-Weld, a structural hotmelt. Some are using it to attach face frames to cabinets; some are using it for frame and panel doors (no waterbased PVA glue=no risk of sunken joints=assemble and go); lots of other applications.I don't know the Titebond version; I'd look closely at Jet-Weld...if it's the same type of glue, I'd prefer to go with the folks that developed it.Do you have to preheat the glue with the Titebond?
*the titebond is a small portable unit with a stand that heats the gun and caartridge. it is not really for continuous duty like a jet-weld. it also costs only 100 bucks, not 500+.
