Hey!
I have a situation I have not done before and I can’t seem to find an easy answer … or maybe I should say the correct answer.
I have a small office inside a building. I plan on using TJI’s for the roof … 11 7/8 “
I have a 14 ft opening on one end.
Long story short but we don’t know who the wall will be finished eventually … one door .. double doors … maybe a sliding curtain wall to open the office to the shop.
So, easiest way I can find to leave the most options is just to put up a couple of 16″ LVL beams and we can decided at any time in the future what is going there (16″ as the roof is being used for storage and the beam needs to carry the load of the roof / floor over a 14 ft span).
Problem … and I would have the same problem if I was going to put a 2 x 4 wall under the end of the TJI’s ….. so two LVL’s will have a width of 3 1/2″ (same as a 2 x 4 wall). I need 3 1/2″ of bearing length for the TJI’s. So if the TJI’s take up the entire top of the LVL’s (or top of the 2×4 wall) where to you put the rim board?
Do I put a spacer between the LVL’s … or use a 2 x 6 wall ????
Seems like it should be a simple question. When I look on the web sites, I see TJI’s and rim board sitting on the top sill of a wall … but this does not give enough bearing area.
If it is a wall, I can simply bump it up to 2 x 6 … but what do you do in the case of two LVL’s ?????
Thanks ….. Mike
https://www.weyerhaeuser.com/woodproducts/document-library/document_library_detail/tj-9001/
see page 4
Thanks! I had not seen this document.
I was looking at others on their sit that showed the strength of the joist was reduced (or increased) by about %25 by going from 1 3/4" to 3 1/2"
Guess I am being too paranoid. Just wanted to make sure I build it the best I can.
Thanks!
https://www.weyerhaeuser.com/woodproducts/document-library/document_library_detail/tj-4000/?view=yes
also, note on page 7 and elsewhere states that the tables are prepared assuming 1 3/4 inch end support.
the other notes you saw apply, in that you could increase the load if you increase the bearing width at the end.
You did not say how long, spacing or flange thickness of the TJI you plan to use, but you should be able to find the application in one of the tables.
This doc also has construction details in the back.
