To cut a truss or not to cut?
| Posted in General Discussion on July 2, 2001 05:11am
Direct vent gas fireplace. Truss runs parallel to the back wall about 8″ out. I need to run vent which requires a an 11″ x 11″ hole. Do I notch out the double top plate and drywall nailer on the interior non-loadbearing wall or cut the bottom chord of the truss and fix it somehow? I know they say “never cut a truss”, but I’m really tempted. Trusses are 24″ o.c. Why can’t I weld up a little c-shaped deal out of steel tubing with flanges on the ends, bolt it in and then cut out a section of the 2 x 4? Seems like I could get more clearance to combustibles that way. The pipe requires 1″, but I always sleep better with more.
Thanks.
  1. bear_ | Jul 02, 2001 05:11am | #1
    Direct vent gas fireplace. Truss runs parallel to the back wall about 8" out. I need to run vent which requires a an 11" x 11" hole. Do I notch out the double top plate and drywall nailer on the interior non-loadbearing wall or cut the bottom chord of the truss and fix it somehow? I know they say "never cut a truss", but I'm really tempted. Trusses are 24" o.c. Why can't I weld up a little c-shaped deal out of steel tubing with flanges on the ends, bolt it in and then cut out a section of the 2 x 4? Seems like I could get more clearance to combustibles that way. The pipe requires 1", but I always sleep better with more.
    Thanks.
A New Approach to Foundations
