To Glue or Not to Glue
Nivek | Posted in Construction Techniques on February 14, 2003 06:18am
I’ve installed several hardwood floors so far but while pulling one up the other day I noticed the two starting rows were face nailed and glue down.  Is this the better technique?  I’ve been face nailing these rows with success but was wondering if doing both is better because I will do it if it is.  Dosen’t the floor need to expand and how can it if those rows are glued?  Will it expand in the other direction? Why would I leave 3/4″ space for expansion next to the wall and then glue down the starting rows so they don’t move?
I’m just trying to refine technique so I can do the best job for my clients.
thanks
Kev
  1. HeavyDuty | Feb 14, 2003 06:55am | #1
    I know the movement tends to go more to the tongue side so I don't think there is much difference in the outcome if you glue the first two rows.
    Tom
    JDRHI | Feb 14, 2003 07:48am | #2
    I dont know for sure that two rows being glued will cause major problems, but I wouldnt do it. I dont see gaining anything from it, so why take the chance? Face nailing is more than adequate.
    J. D. Reynolds
    Home Improvements
    "DO IT RIGHT, DO IT ONCE"
  3. patren61270 | Feb 14, 2003 08:50am | #3
    To Kev
         Just a thought........Wood floors have a tendency to move. Were the boards that were glued split anywhere? I would think that the flooring would fail before the glue and thus cause the flooring to split along the grain.
    JACK.
  4. DavidBarDov | Feb 14, 2003 11:47am | #4
    I have never seen any manufacturers reccommend gluing.  I always read the manuals.  Guarantees are worthless if you don't follow the instructions.  Yes, floors move.  Sometimes they get wet.  Sometimes pieces of them have to be replaced.  Do yourself a favor.  Do it the way it says.  Face nailing works fine.
    1. Flathumb | Feb 14, 2003 09:16pm | #5
      I have seen a manufacturer recommend gluing wide planks, but as you say always read the manuals
