It is time for my daily constrction question. Aftre I put my siding on do I put the black building paper on. Or do I just put on the stucco paper and wire. Some reason I though I hve seen it done with the building paper and then the stucco paper. Thanks Hat
The code requires installing an approved material to slow the spread of fire between floors and adjacent vertical and horizontal cavities — here are the allowed materials and required locations.
Hat, I hope you mean sheathing, not siding. After your sheathing, put on two layers of Grade D building paper. If you can't find Grade D paper use two layers of 15# tar paper. (It comes in a double layer roll.) Then put on your wire lath. Then stucco.
Steve
Sorry that's what I meant. Sheathing. Do I put windows and doors in before I wrap? Thanks Hat
