toe kick sawcut
| Posted in Construction Techniques on July 29, 2005 04:40am
Hello,
    I will be replacing the floor in a kitchen and I need to removethe subfloor . It is 3/4″ particle board and it was installed before the cabinets were set. How do I get a saw cut under the toe kick without removing the cabinets?
The chiseler
  1. gregb | Jul 29, 2005 04:44am | #1
    Try using a toekick saw. Rental yards have them, or you can buy one here...
    http://www.amazon.com/exec/obidos/tg/detail/-/B0000224Q9/qid=1122601379/sr=8-1/ref=sr_8__i1_xgl60/102-8489676-1574511?v=glance&s=hi&n=1000
  2. DANL | Jul 29, 2005 04:55am | #2
    I asked the same question not too long ago and was told pretty much the same answer--toe kick saw and was warned to be careful using one as its blade is a ways from the motor so it tends to twist the whole thing in your hands and be dangerous. I chickened out and just chiselled. So happens there was a seam about a foot away running parallel to the kick, so one I sort of scored the particle boards, I lifted up at that seam and the board snapped and pulled away from under the toe kick. (Someone else had suggested cutting a joint a foot or two away and begin prying it up there.) Was surprisingly easy once I had done the chiselling. (Doing the chiselling was a pain though! But you don't have to be real careful--just sort of making a score line worked well enough that the board broke along that line when I pried.) I suppose if you have like 40 feet of this to do it'd be different--I only had about ten.
  3. jericho | Jul 29, 2005 04:58am | #3
    depending on the clearance height and the length of the run, a fein multimaster might do the trick.
    EricPaulson | Jul 29, 2005 05:06am | #4
    If the counter top allows ( not stone or built in place solid surface or tile) I would consider removing the cabs.
    But that's just me.
    Eric
    It's Never Too Late
    To Become
    What You Might Have Been
    [email protected]
      Dinosaur | Jul 29, 2005 09:08am | #5
      I concur. Pull the cab. It's a base cabinet so it might not even be screwed to anything. Detatch the plumbing, get a helper, and pick the thing up and walk out with it....
      Dinosaur
      A day may come when the courage of men fails,when we forsake our friends and break all bonds of fellowship...
      But it is not this day.
        EricPaulson | Jul 29, 2005 02:25pm | #6
        ................great minds..............It's Never Too Late
        To Become
        [email protected]
          Dinosaur | Jul 29, 2005 06:04pm | #7
          ...pshrink alike....
          Dinosaur
