Toilet Flange connection/confusion
merlvern | Posted in General Discussion on January 12, 2014 12:34pm
hello all,
I have this type of waste pipe for my toilet……i’ve never run into anything like this and i had a few questions that my local big boxes couldn’t answer. additionally, they only had flanges for pvc and cast iron.
1) is this lead?
2) it protrudes about 1/2″ above level of tile…..do i need to trim it flush?
3) it angles to the side where it joins the main stack (that runs horizontally)….so i cant push a vertical flange into it very far
4) is there a particular type of flange that i need?
thanks everyone….i really (as always) appreciate the help!
john
  1. merlvern | Jan 12, 2014 04:07pm | #1
    and another view
    1. DanH | Jan 12, 2014 05:12pm | #2
      Hard to tell if it's cast iron or lead.  If it's lead you'll be able to shave off shiny bits with a pocket knife.
      If it's lead it's been a bit mangled.
      What is the construction of the floor?  Frame?  Concrete slab?
      1. merlvern | Jan 12, 2014 05:34pm | #3
        the floor is framed, covered by 3/4" ply and 1/2" on top of that with marble tile......all new
        the pipe cuts easily with a utility knife
