Toilet installation, cast iron
| Posted in General Discussion on January 28, 1999 08:12am
I am trying to install a toilet in my basement. There is a rough in with a 4″ cast iron pipe in cement. The floor will be tile. How do I attach a flange, etc? Any suggestions?
  1. Guest_ | Jan 27, 1999 09:16am | #1
    Oatey makes a closet flange that fits inside 4" CI pipe. You set the flange where you want it, then tighten down a couple of screws that expand a rubber ring that secures the flange in the pipe. You should also fasten the flange down to the concrete/tile floor with three or four anchors to hold it solid.
  2. Greg_Johnson | Jan 28, 1999 08:12pm | #2
    I am trying to install a toilet in my basement. There is a rough in with a 4" cast iron pipe in cement. The floor will be tile. How do I attach a flange, etc? Any suggestions?
