Both toilets, one on first floor, the other on second floor, after flush and fill, lose a quarter inch of water from the bowl within 10 minutes after fill and then stabilizes. Background: 4 unit condo. Each unit shares a common wall with two other units. Two units share the same 3-4″ vent stack thru roof. Solutions?
Understand the difference between estimating and cost planning, and don't let your sweat equity evaporate into budgeting mistakes.
Check to see if the vent is blocked.
You might have a syphoning issue.
What is the plumbing like below the comode? Traps installed right? Wierd..Inform if solution found please.
All I ever wanted in life was an unfair advantage...
