too smooth
rich2 | Posted in Construction Techniques on February 13, 2007 10:53am
  I have repaired cracks in plaster walls with joint compound then painted. The repair stands out because the texture of the wall is different from the repair.
  The plastered wall has a grity appearence while the joint compound is smooth.
  Is there a way to match the textured plaster?
    SamT | Feb 13, 2007 11:31am | #1
    Never done that, but the first thing I would try would be;
    After final sanding, wet and wring out a piece of Burlap, then press it into the sanded mud.
    I think I would have to try different wetnesses and pressures and different daubing techniques to get it right.
    Maybe try final sanding with damp Burlap.
    Just consider this a bump.
    SamT
    Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either. [Einstein] Tks, BossHogg.
    IMERC | Feb 13, 2007 11:45am | #2
    you didn't say what kind of texture you have or what it looks like...
    so this is a guess...
    "paint" it with thinned joint compound and a short nap roller..
    feather the patch into the existing texture... you may have to "paint" it several times to get a match...
    or use the spay can orange peel and experiment with that..
    WOW!!! What a Ride!
    1. Piffin | Feb 13, 2007 02:35pm | #4
      Maybe some sand on that roller?
        IMERC | Feb 13, 2007 02:40pm | #5
        that would work....
        but it would be nice to know what texture we're trying to match..Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
  3. Piffin | Feb 13, 2007 02:34pm | #3
    You could use plaster - or add grit ( fine sand) to your patching compound and experiment. That will make the trowel skip and chatter so you would then need to sponge it it
  4. RalphWicklund | Feb 13, 2007 05:11pm | #6
    I use Perlite mixed with primer to simulate the sand texture. Applied with a 4" roller and feathered out. Reapply if not enough or wipe if too much.
  5. gb93433 | Feb 13, 2007 06:26pm | #7
    Depending on the texture but a lot of times shortly after I do the joint I use a bristle brush and quickly run it directly across the joint. It tends to pick up the existing texture already there.
