TOOL REPAIR: Delta power miter box
Jake0358 | Posted in Tools for Home Building on January 9, 2009 06:09am
Situation: I have a very old Delta 34-010 power miter box.
Yeah, when I say it is old, believe me, it is. My guess is
that it is 30 years or so. It was given to me and I use it
as a chop box. Well, the belt went on it, so I brought a
replacement belt. The problem is that there isn’t enough
clearance to slide the new one on. Does anyone know where
I can get the instructions on how to replace this?
  1. calvin | Jan 09, 2009 06:50am | #1
    I'm thinking the last time I replaced mine I just slid the belt on.  Don't remember if it was that way, been years.
    If I had that question, I'd call Tim at Electric Tool and repair.  Tell him I suggested it.
    http://electrictool.com/
    http://www.quittintime.com/
  2. USAnigel | Jan 10, 2009 06:01am | #2
    Looks like its a tight fit from the drawing. Is there a "ridge" to get the belt over? If so you might have to remove the pulley and slide it back on with the belt at the same time.
    1. Jake0358 | Jan 10, 2009 10:01pm | #4
      USA: I can't remove the pulley. My guess is that it was
      "pressed" into it's position when it was manufactured.
      There is a "hub" at the end of the splined shaft of
      the pulley assemble, and this is where there is very
      little clearance. At this point, I think I'm going
      to use a little silicone spray and try again to slip
      it into place.
      1. rez | Jan 18, 2009 12:09am | #5
        Did the spray work?
        94969.19  In the beginning there was Breaktime...
        94969.1  Photo Gallery Table of Contents
        1. Jake0358 | Jan 18, 2009 11:26pm | #6
          No. It appears that the only way I can get the
          belt replaced is to take it to a "professional"
          tool repair shop. I'll do so given the oppertunity
          and post the out come
    dedhed6b | Jan 10, 2009 06:42am | #3
    I have oe set up in m garage for cut offs and simple trim when I don' want to set up my scms. I f you don't get any answers I will take it apart tommow and see what's up.
    "Shawdow boxing the appoclipse and wandering the land"
    Wier/Barlow
  4. USAnigel | Jan 19, 2009 12:05am | #7
    Hi Jake
    I just had a look at the parts sheet again. Looks like the flange is removable. Check out the parts list.
    http://www.acetoolrepair.com/34010-p-273.html
    Might take some soaking before pulling it off. A little heat maybe.
    1. Jake0358 | Jan 19, 2009 12:27am | #8
      USA,Thank you for your input; however, items no.
      18, 19, 20, 21, 22 are firmly attached together
      with in item no. 24 and cannot be removed.
      I can only assume the componets are "pressed"
      into place or there is a/are locking spring
      washer(s) that snap into place and act as keepers
      once the pieces are assembled.
      1. dovetail97128 | Jan 19, 2009 01:13am | #9
        Operating from memory here. I recall having to struggle slide the splined drive belt over the matching spline shafts.
        Nothing to remove, just struggle until it slips on. Bet I still have a couple of extra belts somewhere in the shop.
  5. AitchKay | Jan 22, 2009 08:57pm | #10
    I had one back in the 70s, and I know I replaced the belt.
    IIRC, I slid it over the big gear, then "walked it over the flange of the little gear by turning the arbor, sort of like the derailleur on a bike -- it's a heck of a lot easier when the thing is turning.
    That's the one with the wood table, isn't it? I made custom tables, extra-long, and glued solid triangular kneebraces to the bottom of the overhangs. A 1/4-20 machine screw threaded through the braces to push against the sides of the metal base, so I could adjust them flat, with no droop.
    And instead of just a straight rip of particle board, I bulged it out right up to the angle scale. The tables lasted a lot longer that way, because the stayed solid, and uncut, at that outside edge. But even so, one attic job and they were just about history.
    AitchKay
  6. MSA1 | Jan 23, 2009 12:23am | #11
    If you cant slip the belt over the pulley, try cutting the belt and threading it through........oh, Wait, forget it.
    1. DanH | Jan 23, 2009 02:20am | #12
      You can always tape it back together with duct tape.
      1. calvin | Jan 23, 2009 02:53am | #13
        Dan, pantyhose for belt repair.
        Don't leave home without them.A Great Place for Information, Comraderie, and a Sucker Punch.
        1. DanH | Jan 23, 2009 03:26am | #14
          That'll go over well in the locker room.
          1. calvin | Jan 23, 2009 03:35am | #15
            You got it all wrong.
            Slip 'em under the seat.
            Sort of a trophy thing.
            Comprende'A Great Place for Information, Comraderie, and a Sucker Punch.
          2. DanH | Jan 23, 2009 03:37am | #16
            And if the wife finds them? It'd be better if she caught me wearing them.
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
