tool to re move alum siding
jk3 | Posted in Tools for Home Building on April 3, 2005 11:34am
i read in a recent discussion about a tool to unzip alum siding and can not find it now. can anyone help. thanks
  1. berg | Apr 03, 2005 11:45pm | #1
    that would be fantastic my mothers house is al siding
    very difficult to repair
    any hints out there from you siding professionals
  2. gregb | Apr 04, 2005 12:09am | #2
    You can usually find a siding zipper at a good lumberyard, or here's a link to one at Amazon.
    http://www.amazon.com/exec/obidos/tg/detail/-/B00004SUQW/qid=1112562467/sr=1-25/ref=sr_1_25/102-8489676-1574511?v=glance&s=hi
  3. ponytl | Apr 04, 2005 12:35am | #3
    around here you're lucky if some crackhead hasn't removed it for you and sold it for scrap... removal tool.... 1 crackhead... cost zero....
    pony
    1. gregb | Apr 04, 2005 12:53am | #4
      That reminds me of driving down a couple alleys in the ghetto years ago. ALL the backsides of the garages that had alum. siding/gutters were stripped clean for blocks on end. Seems the addicts would come by at night & liberate the alum. from the backs of the garages, one after another.Another time I was driving by an old church with a steeple that must have had a 36/12 pitch on it, & was at least 100 feet in the air. All the copper flashing & hips had been stripped off. Absolutely amazing the lengths (& heights) the crack-heads will go to in order to get a fix.
    2. jk3 | Apr 04, 2005 12:54am | #5
      good one lol
      1. DanT | Apr 06, 2005 04:10am | #8
        I use the vinyl tool, just like with vinyl.  Wears them out in short order but works great.  Once I get it started I use my hands.  When you put it back together it tends to have unbent the 90 at the bottom of the piece so the siding is a bit loose.  We take a wooden block and tap the bottom of the siding to tighten it back up.  DanT
    JeffBuck | Apr 04, 2005 02:42am | #6
    the "unzipper" works ok ...
    I think they work better on vinyl.
    for aluminum ... I like using a wonder bar. Just work at it slow ... get one seam popped ... then zip away by hand.
    last year I unzipped then rezipped a whole gable wall. Had to do some repair work to the framing and couldn't find matching siding ... so had to be real careful.
      Buck Construction
       Artistry in Carpentry
            Pgh, PA
    1. jk3 | Apr 06, 2005 03:04am | #7
      thank you, looks good
Mortar for Old Masonry
