Tools for soldering sheet copper
carpenter97 | Posted in Tools for Home Building on June 28, 2011 07:27am
I’m building a pair of exterior doors and I want to make a copper sill pan and head cap flashings. I’ve been looking online for tools and am not sure what’s the best and cheapest way to go. I don’t need a fancy rig for the three or four exterior units that I build each year. I just want a good setup. Thank you.
carp97
  1. DanH | Jun 28, 2011 07:56pm | #1
    I'm sure seeyou will have better advice, but I think what you basically need is a good sized soldering copper ("iron") and some sort of torch or stove.  Plus a few appropriate tin-bending tools (eg, sheet metal pliers) and maybe a couple of small welding-style clamps, or whatever clamps you can make do with.
  2. seeyou | Jun 29, 2011 08:02am | #2
    If you fold the pieces right, all you need is a plumber's propane torch. Just clamp and solder before you install to keep from starting a fire.
  3. ImoutYOUWERENEVERIN | Jul 05, 2011 08:56pm | #3
    Thanks guys.
