Toothbrush in toilet
munson01 | Posted in General Discussion on December 18, 2007 10:15am
Yeah, I think I saw this on Seinfeld once! Hello to all and thanks for all the help you provide to us novices. Well a few days ago my 2 yr old threw his toothbrush into the toilet, then my 3 yr old followed up with a flush. Now the toilet is very slow to fill up and not all material makes it down on one flush. Its not affecting any other toilets in the house. I’ve got the shop vac out and got all the water out, tried reaching as far as I can up there and cant reach anything. My only other guess is to take the toilet out and try it from the other side. But I still wont be able to reach up that far cause it takes a 90 deg bend after about 2 inches. So my question is, do I need to get an auger and run that thing up in there till it hits the toothbrush, or just get a snake? It seems like I need something to grab the brush and pull it out, not just push it out. Any ideas? Once again, thanks for the help in advance.
    IMERC | Dec 18, 2007 10:18pm | #1
    since you'd like to make a fest out of this....
    http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=97445.1
    WOW!!! What a Ride!
    1. DanH | Dec 18, 2007 10:19pm | #2
      Ya beat me to it by about 30 seconds.
        IMERC | Dec 18, 2007 10:22pm | #3
        I couldn't resist...
        IMERC | Dec 18, 2007 10:24pm | #4
        I still say lye in the bowl will disolve just about any tooth brush out there if a snake doesn't do the trick...
        IMERC | Dec 18, 2007 11:50pm | #8
        guess that link terrorized the poor OP...
        1. DanH | Dec 19, 2007 12:00am | #9
          I thought we were pretty gentle.
            IMERC | Dec 19, 2007 12:02am | #10
            seemed that way....
            maybe it was the contents of the link that feared him...
          2. BillBrennen | Dec 19, 2007 12:11am | #12
            I clicked on the thread thinking, "Gunner is so grateful for our brotherly support in his toothbrush in toilet thread that he's hosting the next fest to thank his buds at BT."Bill (edited for typo)
            Edited 12/18/2007 4:12 pm by BillBrennen
          3. DanH | Dec 19, 2007 12:13am | #13
            I think lots of times newbies post and then can't find their posts (especially when they end up in Breaktime Fests).
            IMERC | Dec 19, 2007 12:23am | #14
            so let's gp over to the Op's place...
            crank up a fest... use the terlit for the central trianing aide....
            and make suggestion as to how to fix his terlit...
          5. DanH | Dec 19, 2007 12:27am | #15
            Boy you really want to scare him away, don't you? Just the sight of several of us at his door would be enough to send him into shock (or for his shotgun).
            IMERC | Dec 19, 2007 01:12am | #16
            it'd all be part of the festivities...
          7. User avater
            BillHartmann | Dec 19, 2007 04:32am | #17
            Just keep the axes behind your back until you are inside the house..
          8. rez | Dec 20, 2007 04:58am | #28
            a newbie post in Breaktime Fests again.
            There has to be psychological ramifications for this.
            be rami rami krishna rami or just another monkey on a stick
          9. User avater
            IMERC | Dec 20, 2007 05:08am | #29
            partying is way better than fixing terlits..
  2. Danno | Dec 18, 2007 10:26pm | #5
    Welcome--you must be new! First, you probably should have posted your question under "General Discussion" or something, but maybe the Sytem Operator will move it. I don't think you can move it, and if you post again, you'll just confuse people.
    Second--this very question was asked recently and got a lot of discussion. You may be able to find the discussion by going to the top of the place where it lists all the discussions and click on "advanced search" and when it asks for words to match, try "toothbrush" or "toilet." It was still listed in the discussions yesterday, I think, so you can narrow the search down to that time period.  Good luck. Others are more web site savvy and can tell you which discussion and how to bring it up by number, maybe.
      IMERC | Dec 18, 2007 10:29pm | #6
      just tell him to click on this...
    2. munson01 | Dec 19, 2007 12:09am | #11
      danno, thanks for the info. Yes I am new here and did try and do a search, but I did not get anything back. I must have done it wrong. Thanks for the suggestions.
      1. Danno | Dec 19, 2007 04:40am | #18
        You did see IMERCS post, right? If not, here it is--just click as he says:
          IMERC | Dec 19, 2007 04:42am | #19
          we tried that...and he disappeared....
          seems something got him...
          1. Danno | Dec 19, 2007 05:03am | #20
            I thought we were unusually restrained, so I don't think it was us that scared him away! ;-)
            Maybe after Sysop moved the thread, the OP wasn't able to find it again (as you said).
            (When I first saw the post I thought, holy smokes, did someone reopen Gunner's thread and move it! Fun though it was, once was enough!)
            IMERC | Dec 19, 2007 05:08am | #21
            maybe the OP hasn't got up off the floor long enough to reply...
          3. northeastvt | Dec 19, 2007 05:29am | #22
            Or he may still be reading the post in that thread. It wasn't a short story.
            Northeastvt
            IMERC | Dec 19, 2007 05:38am | #23
            that could be so...
  3. runnerguy | Dec 18, 2007 10:37pm | #7
    I suggest in addition to "General discussion", Construction Techniques", "Business", etc. we have a new catagory......"Toothbrush in Toilet".
    Runnerguy
    IMERC | Dec 19, 2007 05:39am | #24
    you still with us????
    WOW!!! What a Ride!
      Heck | Dec 19, 2007 05:42am | #25
      yur the one who sent him down the drain...
        IMERC | Dec 19, 2007 05:45am | #26
        nobody told him to climb in and pull the chain...
    2. Piffin | Dec 20, 2007 01:53am | #27
      His hand is still stuck in the trap;)
Installing Prefinished Cabinet Molding
Use these assembly techniques when installing crown risers and molding to minimize visible gaps and nail holes.
