Top Plate gap – basement
sloped_floor | Posted in Construction Techniques on February 3, 2020 08:09pm
So, I’m framing non load bearing interior basement walls with a sloped floor. I built the first wall on the floor and stood up and found I’m 3/4” short.  Rest of the walls I stick up built and are tight.  I’m using a double top plate.
Any ideas to save the first wall I built?  The Shims I have slide right through.  A 1×4 fits great, but I’m worried the inspector will call me out for a 1×4” between 2×4 double top plates.
On this basement ceiling, there are hvac air ducts that prevent me from going any closer between the double top plates. First top plate I have had to cut between the air ducts.  The second top plate currently is uncut. Hope that makes sense
1. Cut very top plate between air ducts
2. 3/4” gap
3. top plate
4. Studs
5. pressure treated sill plate
This wall is about 6’ long and will support a basement soffit/chase.
Thanks for the advice.  Kind of thinking of rolling the dice with the inspector.
  1. jlyda | Feb 04, 2020 01:33am | #1
    Having the 3/4” will not keep the inspector from passing you. He/she may make a comment, but won’t tag you. The only items they really look for in basement walls are proper stud spacing, that everything is nailed properly, treated wood is only wood touching concrete/masonry, studs have to be at least 1/4” away from foundation walls (unless treated studs are being used or you have installed rigid foam to foundation walls) and the most frequently tagged item of fire stopping.
  2. andy_engel | Feb 04, 2020 10:44am | #2
    It won't be a problem. I always frame basement walls short so I can raise them. Coupla shims and you're good to go.
  3. sloped_floor | Feb 04, 2020 12:50pm | #3
    Thanks all. Appreciate the support
Outdoor Lighting
  • A Postwar Comeback
