Ran across this article on the history of topping out practices. Since there was an extended discussion of this some time back on Breaktime, I thought I would toss it up here for those of you interested in such things. This article is on topping out for steel structures, but the history references are still relevant. I would have referenced the past discussions, but I can’t figure out the right choice of terms to find them… (Note that this is in the Adobe .pdf format)
http://www.modernsteel.com/msc/0012_05_christmas.pdf
To prevent moisture buildup and improve performance, install a continuous air barrier—such as drywall or specialized membranes—under tongue-and-groove boards or other interior wall paneling.
Ran across this article on the history of topping out practices. Since there was an extended discussion of this some time back on Breaktime, I thought I would toss it up here for those of you interested in such things. This article is on topping out for steel structures, but the history references are still relevant. I would have referenced the past discussions, but I can't figure out the right choice of terms to find them... (Note that this is in the Adobe .pdf format)
