Tornado shelter – Ideas?
xxxxx | Posted in General Discussion on December 29, 2008 05:47am
Visited DD & SIL in Omaha for Christmas & talked about, among other things, their desire to build in a ‘huddle space’ in their basement for protection from tornados.  They have a four level split, with the lowest level or basement being app. 22′ square, of block construction, & mostly below grade.  There is one level of house above that area.
They don’t really want to go to the work and expense of a concrete shelter but had wondered if in the process of finishing the basement off, they could use 2x framing to build a small area in the southwest corner, self-supporting & separate from the rest of the house framing.  It would be sheeted with plywood to protect them from falling/flying debrei (sp?)  should the house take a hit.
The question is what size & spacing would the framing be & what thickness for the plywood?  The space would be approx. 6’x6’x6′ high which would have the whole thing below grade.  I also feel anchoring to floor & walls would be a given.  I’ve had no experience with tornados, but I understand they can do some pretty weird things, so I’m not sure if this idea would be adequate or just give a false sense of security.  Any experienced feedback would be appreciated.
Paul
  1. brownbagg | Dec 29, 2008 06:15am | #1
    there a site , a government site. Fema, that talks about this exact question
    1. Catskinner | Dec 29, 2008 06:27am | #2
      http://www.fema.gov/plan/prevent/saferoom/criteria.shtmhttp://www.fema.gov/plan/prevent/saferoom/fema320.shtmAdditional information about Safe Rooms available from FEMA:
      Taking Shelter from the Storm: Building a Safe Room Inside Your House. L-233. Brochure providing details about obtaining information about how to build a wind-safe room to withstand tornado, hurricane, and other high winds.Taking Shelter from the Storm: Building a Safe Room Inside Your House. FEMA-320. Manual with detailed information about how to build a wind-safe room to withstand tornado, hurricane, and other high winds.
  2. ponytl | Dec 29, 2008 06:40am | #3
    a few points... I have no experience in this but have researched it a bit...
    bolts from the slab through the roof structure... what i saw was 3/4" steel rods through a 4" x 1/4" thick steel plate all the way around the top... the 3/4" bolts were on 30" centers... the walls were framed with 2x6's doubled on 12" centers (plan on supporting the weight of whatever might be on top of you)  sheathed in 3/4" plywood doubled on both sides and all glued and screwed... the door was small and steel  and had a small maybe 4" sq window...something like bullet proof glass... maybe 18" and opened in... there were boards inside to brace the door closed... there were a few pipes for ventalation... and a funnel and a tube out to pee in...
    might have been in mother earth news...  but they said you should survive in it...
    just what i remember... I'm sure a google search would turn up a ton of info..
    P
    FatRoman | Dec 29, 2008 07:18am | #4
    Texas Tech has a great lab on that. Here's some info with suggestions from them on further documentation.
    http://www.wind.ttu.edu/Shelters/WindProtection.php
    'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
