Has anyone used a Dingo? Look like a great machine for tight access jobs. I have not had any hands on experience, but I watched as the rep. dug a 30″ hole with the auger attachment (thru 3″ limestone into clay) and was pretty impressed.
David
David
Listeners write in about greedy dormers and shop class and ask questions about steamy storm doors, fireplaces, and insulating a basement.
David,
I own the 322 or 522D. I can't remember the numbers but is is the diesel version. It pretty much does anything I want it to. I build alot of fence, so I have the pivot auger head for it. It will dig pretty much anything a bobcat will, but it doesn't weigh nearly as much so it takes longer in rocky or hard soil. They do have a backplate for it that adds to the downpressure for drilling. I've also rented the trencher attachment for it to bury a power feed to a detached garage I built for someone and it worked great. The controls are all done by thumb, so it takes some getting used to but its easy. The best part is I can get it into any space at least 42" wide. I used it to bring in about 3 yards of fill dirt along that garage on the side with only 6' of space where I would have needed a wheelbarrow because a bobcat wouldn't fit. They aren' t cheap. I paid $18,000 with the bucket and auger attachement and 9" and 12" augers. You can also haul it in the back of a 3/4 ton or 1 ton pickup if you need to. I went ahead and got a trailer for it. I hope this helps. I'm sure I can answer more questions if you have them.
Cole
Cole Dean
Dean Contracting
