Recently had to install Toto toilets as replacements on two different jobs. One was a fancy one piece self cleaning electric model with all the bells and whistles. We had to move the existing water supply valve. This was after everything else was completed. We went through the wall behind and repaired the drywall rather than have to fix the tile. The next job involved 2 piece units that should just be an easy swap. No!!!! Again the toilets would not work with the existing supplies. Beware, if you are using these suckers. You may get more work than you barganed for.
In older homes like these, the main remodeling goal is often a more welcoming, more social, and more functional kitchen.
I guess you're not in Kansas anymore.
