Trail Construction Advice
atlanta86 | Posted in General Discussion on November 17, 2024 02:24pm
I volunteer for a Georgia association that has a little over 2 miles of trails around a lake with some “low country” areas.  In the 80s they built a sort of boardwalk in the low-lying areas constructed of pressure treated framing (usually 4×6) and landscape timbers for “treads”.  These were built in the low (wet) areas the framing is rotting away on much of it.
We want to replace the “boardwalks” but haven’t found a good design for something new.  There are a lot of composite products that could replace the landscape timber treads, but they still recommend framing with pressure treated?  We also need to design a way to anchor the beams – in most areas they were just layed over 4 x 4 stacks.
Trying to find something that will look natural but resist rot.
Any advice appreciated.  Thanks.
  1. designbing | Nov 19, 2024 11:04am | #1
    The 40% pressure treated will last for quite a while. But then these types of trail situations are never going to last forever, that's why people like us do trail maintenance.
    ct_yankee | Nov 19, 2024 06:30pm | #2
    Today's ground contact pressure-treated lumber is garbage compared to what was available in the 1980s and has a disappointing life expectancy.
Townhouse Transformation
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
