transition dry to durock above shower
JayP99 | Posted in Construction Techniques on August 3, 2018 11:34am
How would you handle the seam where durock of shower surround meets drywall above the tilework ?
  1. mgmahan | Aug 03, 2018 12:21pm | #1
    Where does the tile end?
    I assume you are stopping the tile at this juncture. If you intend to finish the edge with surface bullnose, just lap the tile over the seam. Ideally most of the top tile would be on the backer board.
    Mike Mahan
    1. JayP99 | Aug 03, 2018 12:46pm | #2
      thanks Mike,
      Tile will stop near it, so I was debating to use durock seam cement or drywall mud/tape at this last seam.
      Planning on a redguard or similar sealer too, if it matters.
      1. mgmahan | Aug 03, 2018 01:42pm | #3
        use mesh tape set in thinset.
  2. florida | Aug 03, 2018 08:22pm | #4
    We mud the joint then carry the tile at least one tile past the joint.
