transitioning from copper trunk to PEX branch
boogieWoogie | Posted in General Discussion on April 4, 2012 05:02am
Hi Folks,
I’d like to add a 1/2″ PEX branch plumbing to an existing 3/4″ copper trunk.  I would have expected to use a fitting that has 3/4″ female sweat ends on the straight-thru portions, and 1/2″ barbed PEX fitting on the branch outlet of the tee, but I can’t find this anywhere.  I’ve seen others online asking about this too, but a lack of definitive answers.  Can anyone tell me why this type of fitting doesn’t exist?  What’s the best-practice of how to tap into this sort of copper trunk w/ PEX then?
Thx,
BW
  1. rdesigns | Apr 04, 2012 05:45pm | #1
    You could use a 3/4" tee with
    You could use a 3/4" tee with a 1/2 branch, all soldered connections, and then solder in a 1/2"  pex  adapter to get started with pex.
    Or, you could do the same thing using sharkbite fittings unless you like soldered connections better.
    xxPaulCPxx | Apr 05, 2012 05:29pm | #2
    Step one: Cut off copper and ream the end for burrs.
    Step Two:  Attach Sharkbite U058LF fitting (3/4" to 1/2" reduction fitting, Lead Free)
    Step Three:  Attach PEX pipe to Sharkbite fitting.
    Done!
