I had a fabricator make a small (2×4) granite countertop for a bath vanity, and cut and install the sink bowl. Now I’ve got to get it back to my house for the install. Does the countertop have to be transported on edge on a cradle (like I’ve seen), or can I just lay it upside down and flat on, say, a piece of plywood in my truck bed? I’m not travelling any great distance – I just want to avoid breaking it. Thanks.
Barsfield,
It's best to transport upright but if you want to do flat use some thick padding like movers blankets.
KK
Thanks. I just don't want to break anything....
Thick padding is NOT a good idea, as it will create stress when you hit a bump. Best is to have a solid, flat, stiff surface under the piece, so that when you hit a bump the same acceleration is applied evenly to every part of it.
And then avoid bumps.
The slab, before making the cutout for the sink, is pretty much indestructable, but once the cutout is made it becomes quite fragile, and any flexing is likely to lead to failure. The pros will typically use a sort of strongback on the piece to protect it, even as they manually haul it from the truck into the house.
I just brought a 33x40 3cm home from the granite yard and I just had it in the bed of the truck, wedged in a groove in the bed liner and propped up against the side wall. (tied in)
I brought a bunch home before, laying on OSB in the bed (stacked OSB, granite,OSB granite eic). It is actually pretty tough stuff if it is supported across the face.
I think you may have missed the point that the piece has been cut to accept a sink. This makes it much more fragile.
Hence the OSB under it.
