I’m looking for a 120v submersible pump to pump out wet foundations and ditches. It’s gonna be knocked around and abused, and I don’t want to have to worry about what I’m pumping through it. Any suggestions?
Discover why linseed oil paint is the go-to choice for Fink & Son Historic Restoration.
I'd recommend something like a Tsurumi pump or equivalent. There's on on ebay right now. I'd buy it if I weren't watching pennies right now.
http://cgi.ebay.com/Tsurumi-Submersible-2-1HP-Water-Pump-LB3-750_W0QQitemZ270325533363QQcmdZViewItemQQptZBI_Pumps?hash=item270325533363&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
John
J.R. Lazaro Builders, Inc.
Indianapolis, In.
“You can either wait for the storm to pass, or you can learn to dance in the rain.â€
"I'll be long gone before some smart person ever figures out what happened inside this Oval Office."—Washington, D.C., May 12, 2008
Are these things the same as "Mud Pumps"? Someone suggested one for dredging the pond, but I've never
heard of one before.
Probably not. I think what you are describing as a mud pump would be a diaphragm pump. As long as the screen doesn't clog, they will pump it. A trash pump will pump water and some solids that would kill a water pump.John
Indianapolis, In.
Mud pump is a common term for a pneumatic diapragm pump. Among other uses, well drillers use them for circulating drilling fluid in a borehole.
Ah, thanks ALL for the insight.
If it's not an ungodly amount of water, this works, especially in tight spaces... and it doesn't need a cord.http://www.jamestowndistributors.com/userportal/show_product.do?pid=597&familyName=Beckson+Thirsty-Mate+Pumpshttp://www.tvwsolar.com
I went down to the lobby
To make a small call out.
A pretty dancing girl was there,
And she began to shout,
"Go on back to see the gypsy.
He can move you from the rear,
Drive you from your fear,
Bring you through the mirror.
He did it in Las Vegas,
And he can do it here."
I used to have a 2" Goulds electric submersible. I think the model I had was referred to as a sewer pump but it didn't have a grinder (some do). Good, rugged unit with a cast housing. Could handle lots of stuff and moved muddy water fast, but not gravel. I've had great luck with a variety of Gould pumps. Grainger carries them.
What you're looking for is considered a 'dewatering' pump. Designed for pumping dirty water out of ditches, mines, etc etc.
Tsurumi, Grindex, Flygt, Gorman Rupp, and a bunch of others make good ones. Grindex are quite forgiving of running dry.
Good point on running dry. I let the smoke out of my 3" trash pump seals one day running it dry.
