So how far would you all travel for work? And would the length of job make a difference? i.e. one day job sure, I’ll drive a while but if it takes 4 months…does that make a difference?
Finally, how do you figure your costs for that? Do you just tack on a flat rate?
An example would be someone calls you to build a large addition three hours away. Do you add anything for your travel time or just work it as normally?
3 hours away means 6 hrs travel and 8 hrs production
does this involve employees ?
i'd switch it over to 4 ten hour days plus room and board and that would be my labor cost
we travel 100 miles, time start at the shop and ends at the shop
