Tray ceiling
Reysie | Posted in Construction Techniques on February 16, 2008 01:04am
I,m trying to install a tray ceiling in our foyer , but I’m running into trouble trying to make the corners. I’m not getting the right angles. I’m using 38 degrees for the angle. Can  someone help me?
Reysie
  1. Framer | Feb 16, 2008 01:29am | #1
    38°, is that what you are using for the common rafters?
    Joe Carola
    1. Reysie | Feb 16, 2008 06:31am | #2
      Yes Sir 38 degrees is the common rafters that I'm using.
      Reysie
      1. Framer | Feb 16, 2008 07:25am | #3
        Then your hips/corners will be 28.92° or 29°.Joe Carola
        1. mguizzo | Feb 16, 2008 09:29am | #4
          May I ask how you figured out the angle?
          1. Framer | Feb 16, 2008 04:37pm | #5
            He said that he was using a 38° angle for the commons and probably scribing it with a speedsquare. 38° is roughly 9-3/8/12 pitch. I used my Construction Master Calculator. There are many ways to do it.
            If he wants to just work in degrees, he can do this.
            38 [Pit] [Pit] [=] [Rise] [Hip] [Hip] = 28.92°
            That took 5 seconds.
            But, he doesn't even have to do any math when using the speedsquare. He has his speedsquare set at 38°. Look at the commonnumbers on the speedsquare and it reads roughly 9-3/8".
            So now you know that the speedsquare tells you that the pitch is 9-3/8".So now just set the hip part of the speedsquare at 9-3/8" and that's your hip angle plumbcuts.
            If he wants to use a framing square and the hips are running at 45°, all he has to do is this.
            38 [Pit] [Pit] = 9-3/8" (9-3/8 over 12 on Framing Square for Common Rafters)
            Now, all you do is just hold 9-/38" over 17 for the hips.
            Hope this makes sense.
            Joe Carola
            Edited 2/16/2008 8:38 am ET by Framer
          2. mguizzo | Feb 17, 2008 02:07am | #6
            Thanks.
          3. Reysie | Feb 17, 2008 05:03am | #7
            Thanks Joe for the answer I was looking for, my prayers came through. Keep up the good work. Reysie
          4. tashler | Feb 17, 2008 05:05am | #8
            That's why I love this guy.Just something else to bookmark.Glenn
