Treated plywood – overkill in this application?
Houghton123 | Posted in Construction Techniques on August 4, 2010 07:00am
Situation: concrete slab, 6-12″ of slab exposed above grade, resting on 4″ of gravel and a sheet of plastic.  I’m putting down a plastic vapor barrier and screwing down 1/2″ plywood (all of this to get a little elevation for drainage where the door abuts on a brick patio).  Screwholes will get a shot of poly caulk before the tapcons are driven.  All of this inside an enclosed space.
Space will be used as a studio with occasional overnight guests.  A floating laminate floor will go on top of the plywood, over the usual thin foam underlayment.
I was planning to put down treated plywood, but am wondering if this is overkill.  I realized today that, if I trust the vapor barrier at all, it should be enough that regular CDX ply would be fine, with less outgassing of fumey junk in the occupied space.
Help!
  1. sapwood | Aug 04, 2010 07:49pm | #1
    no treated
    I would certainly not use treated ply in an enclosed inhabited space. And I question the need for the vapor barrier below the floating floor. Wouldn't the vb under the concrete be sufficient to keep the slab dry?
    1. JTC1 | Aug 05, 2010 06:31pm | #2
      I would agree to
      "I would certainly not use treated ply in an enclosed inhabited space."
      I subscibe to this philosophy as does my local building department.
      However......................
      I have been to New Orleans 5 times since Katrina, 4 of those trips we were building for H4H.  Houses we worked on were all elevated roughly 4 feet above grade.  All first floor subfloor framing was ACQ treated and the first floor subfloors were specified as.......drum roll....... 3/4" ACQ treated, T&G, plywood.
      Go figure.
      Jim
  2. Clewless1 | Aug 06, 2010 09:46am | #3
    Side note ... replace all your words "vapor barrier" with "vapor retarder". With most e.g. poly plastics, it is NOT a barrier to moisture migration. It actually has a tested rate of moisture migration. Aluminum foil I believe is the only thing that could be considered a "vapor barrier". The industry has shifted from your term to the one I suggest ... and for good reason.
    just an FYI as you think about moisture, etc.  Other's will give you words of wisdom on the specifics of your question.
    I used some pressure treated plywood exposed in my house. No mention by the BO about it. It wasn't a big area, but it was there non the less.
  3. JTC1 | Aug 09, 2010 07:34am | #4
    Perhaps
    a hold over from CCA treatment days.
    Our local BI's do not want any treated wood inside of a living space with the noted exception of the mudsills.
    Don't really know the rationale behind this, paranoia about gases maybe; I just know it has been their policy for years and did not change with the advent of ACQ, MCA, MCQ, etc.
    Jim
    1. DanH | Aug 09, 2010 07:46am | #5
      As far as I know, none of the common treatment methods in the past or present has an outgassing hazard to any degree.  I can see restricting treated wood to non-finish areas, but I don't see the point in prohibiting it.
      (I hope that, in addition to mudsills, they also allow it in bottom plates on concrete.)
      1. JTC1 | Aug 09, 2010 08:17am | #6
        Not very many
        slab built houses in this county, but yes, bottom plates on concrete are OK / required.
        Jim
        1. DanH | Aug 09, 2010 08:41am | #7
          No basements?
          1. JTC1 | Aug 09, 2010 06:45pm | #8
            About
            90% basements or 1/2 basement + 1/2crawlspace, 9% full crawlspaces, >1% slabs unless a garage or some other type of outbuilding in my county. Beach and coastal areas are usually raised crawlspace of some sort - some are raised pretty far too! - many of these are built on PT pilings.
            New construction in my county = 80% poured concrete foundation walls; full crawlspaces are usually concrete footings and run up in block rather than poured. Minimum footing depth = 32" here.
            Local BI's require PT wood in contact with masonry of all foundation types either poured or block.  Also whether a sill or a bottom plate.
            Jim
