Need some suggestions : Wrapped some replacement posts 6 X 6 on a front porch ,4- 5 years ago [ porch dropped because of weight of snow and ice and rot ] aluminum did not like it [ new chemicals of treated lumber] so had some coil left , tore off older aluminum wrap , wrapped posts with tar paper and went at it again with the remaining coil I had and same but not as bad results ,aluminum bubbling and pitting , any suggestions with-out making the posts look any wider, to match the 1 remaining post that does not get hit with weather, I know some home improvement stores have 2 pc wraps, or I have seen non-wood/composite that is very thin but not sure of the width compared to post width, any help out there?
treated posts and aluminum wrap
ACQ is known to corode many metals, but you were correct in using a seporator. I believe since building paper still breathes a small outgasing cause by drying or ambient humidity may present contribute to your problem. You might find standard duct tape in two layers on the back of the metal where in contact will prolong the life also the use of stainless steel nails as well. A heavy zink coated metal will outlast the aluminim but stainless steel would be the top choice of metal. Hardie board siding and stainless steel fasteners is a good look, economical and with the minimum thickness of 1/4 profile, adds only a 1/2 inch to your post.
Washington Alaska Roof Systems, Inc - Duradek Northwest
You could use some sort of sheet plastic and plastic corners, but it wouldn't look like a plain post then.
I've seen slide-on plastic sleeves for 4x4 posts, but not 6x6, though they may be available somewhere.
Or you might find someone who'll fabricate two plastic Us for you -- simple enough for someone with the plastic stock and a bending brake for thermoplastic. (I've seen this done for commercial work, so there must be people who do it..)
