Trex and other similar products
| Posted in General Discussion on March 31, 1999 07:59am
Mark, I have found the difference in widths of Trex boards to be very annoying when building large decks. The width difference shows up with different lengths. 12 footers may be 1/8″ or more narrower than 16 footers for example. If you have a large deck (over 20′) where you must use a 12 and a 16 butted end to end for instance, this can really goof up your spacing and it looks bad!
  1. G.LaLonde | Mar 31, 1999 07:59am | #2
    Mark, I have found the difference in widths of Trex boards to be very annoying when building large decks. The width difference shows up with different lengths. 12 footers may be 1/8" or more narrower than 16 footers for example. If you have a large deck (over 20') where you must use a 12 and a 16 butted end to end for instance, this can really goof up your spacing and it looks bad!
  2. Guest_ | Mar 31, 1999 07:59am | #3
    I am in the process of designing a deck and patio cover and would like to utilize several curved sufaces. My question is... what do you think about Trex or any similar products? I understand Trex is great for its flexibility and the fact that it does not need to be painted. However, I have also heard that because of the way it is manufactured the thickness and width of Trex boards vary drastically. Any thoughts?
    1. Guest_ | Mar 31, 1999 07:51am | #1
      *On our deck, I did not see the thickness/width inconsistency problem, though I have heard of it. For me, the material was entirely benign and kind of fun to work with. Beware of its wigglyness, though' I wouldn't use it in rails or other long=spanning elements. I'm interesting in finding a good solvent for the stuff -- PVC cement works OK. See Aug./Sept. FHB p.64 for fun with bending Trex.
