Trex for window sills?
| Posted in Construction Techniques on December 28, 2002 07:59am
Anyone done this?  If so what did you think?
  1. xMikeSmith | Dec 28, 2002 06:00pm | #1
    do it all the time.. we get two pieces of sill stock out of every Trex
    Mike Smith   Rhode Island : Design / Build / Repair / Restore
    1. joeh | Dec 28, 2002 07:31pm | #2
      Mike, what do you paint it with? How does it hold up over time? Joe H
      1. xMikeSmith | Dec 28, 2002 08:45pm | #3
        any primer... but we use oil... and any finish...
        stands up better than anything else  we've used.. and it ain't gonna rot out Mike Smith   Rhode Island : Design / Build / Repair / Restore
        1. joeh | Dec 28, 2002 09:23pm | #4
          Mike, I was asking how the paint held up. Seems that stuff would be hard to get paint to stick to, but your picture says it all. Thanks, Joe H
    2. Ragnar17 | Dec 29, 2002 03:26am | #6
      Mike,
      Thanks for the pic.  Are you using Trex for the casings, too?
      Ragnar
      1. xMikeSmith | Dec 29, 2002 04:36am | #7
        no we use GP Prime Trim.. usually 5/4Mike Smith   Rhode Island : Design / Build / Repair / Restore
        1. Ragnar17 | Dec 29, 2002 05:58am | #8
          Mike,
          Using trex for the sill seems like it may be a good idea.
          However, I'm always very cautious at first, so I'd like to ask you a couple of questions if you don't mind.  ;)
          First, how long have you been doing it this way (so that a track record may be established)?  Second, are you aware of a different rate of thermal expansion for trex compared to wood and primetrim?
          Thanks,
          Ragnar
          1. xMikeSmith | Dec 29, 2002 06:17am | #9
            i think we started using trex for trim like this about '96..
            yes the thermal expansion rates are different... but for a sill it won't effect anything, IE.. most of the trex expansion is along the long axis...
            most woods expand / contract with moisture content.... we minimize this by backpriming everything.. GP Prime Trim is very stable..
            trex is milkbottle plastic & wood fiber... the plastic and the paint will keep moisture out of teh wood fiber... so thermal expansion / contraction is mostly from the plastic componentMike Smith   Rhode Island : Design / Build / Repair / Restore
          2. Ragnar17 | Dec 29, 2002 07:30am | #10
            That's good news that you've been doing it since '96.  Must be working!
            You said "the trex expansion is along the long axis..."  By this, do you mean it increases in length (as opposed to width)?
            Do you nail/screw from the bottom of the sill into the end grain of the casing?  And finally, what sort of connection do you use to hold the trex to the window subsill and/or the house sheathing/framing?
            Thanks for the info, Mike!
            Ragnar
          3. xMikeSmith | Dec 29, 2002 07:35am | #11
            we screw right thru the face of the sill into the window sill frame... we countersink the screws and either plug them or bondo them..
             no nails from the sill to the casing , we do caulk that joint.. and our sill has a 10 deg. bevelMike Smith   Rhode Island : Design / Build / Repair / Restore
  2. wrick2003 | Dec 28, 2002 11:36pm | #5
    trex rox
  3. WayneL5 | Dec 31, 2002 01:07am | #12
    I used Trex two years ago for sills and casing on my own home.  Painted with one coat 100% acrylic primer and two topcoats of 100% acrylic.  Caulked with siliconized acrylic latex between the prime coat and the top coats where needed.  It worked well and the paint still looks new, except for dirt.
    Easy to work with, though, since its made from recycled material, will contain an occasional bit of metal.  So, you'll damage fine tools like planers and jointers or cheap table saw blades.
    Some folks may not like the texture, but it did not bother me.
    1. JohnSprung | Dec 31, 2002 02:10am | #13
      There was another post not long ago about using corian for window sills, also seemed to work well.  Window sills seem to be the ideal place for flying termites to land and start eating.
      -- J.S.
