trex /heat gun
rich2 | Posted in Construction Techniques on August 20, 2006 05:00am
  We recently resurfaced a deck with Trex. We used stainless steel trimhead screws and then tapped the mushroom with a hammer. Days later I read an article where the installers used a heat gun first and then tapped the mushroom down. Does anyone know if this makes a big difference and if it makes sense to go back and do it? <!—-><!—-><!—->
  Also the article mentioned countersinking then plugging the hole using the pvc method but it didn’t explain exactly what was involved. Does anyone know?<!—-><!—->
  1. kate | Aug 22, 2006 02:24am | #1
    Bump
    1. rich2 | Aug 22, 2006 06:39pm | #2
       Okay! Thanks for the input,I think.
      1. kate | Aug 23, 2006 12:39am | #3
        A bump just moves your post into the actyive list, so someone who knows something about the topic will see it, one hopes...
    Homewright | Aug 23, 2006 12:51am | #4
    Trex is basically a thermoplastic which when warmed will let you curve it etc.  The mushrooms from the screws will be fine as you've already addressed them.  In the past, and when the job paid for the effort, I took a heat gun, hammer, and wire bristle brush to make the holes disappear.  Heat first, tap flat with a hammer, then scuff with the brush along the grain.  Tedious but it does make the holes go away.
    1. rich2 | Aug 23, 2006 04:15pm | #5
       Thanks for sharing your experience. I feel your pain.
Fast, Accurate Wall Framing
  • Smarter Stop Block
  • Square Walls Solo
  • Deck-Board Pry Bar
