Trimming down rabbeted door stop to fit a 1 3/4 door
Jencar | Posted in General Discussion on February 13, 2015 01:01am
Hey, it’s been a while since I posted (years, in fact!),  I could really use an idea or two.  A customer has a door  they found that they LOVE and want to use it to replace an existing 1 3/8 ” exterior door.  The new door is 1 3/4″.  (also is a righty and the existing is a left hand swing which isn’t as much of an issue) I’ve trimmed a door stop before free hand and it’s a huge pain.  Came up with a jig to use a router, but then you still have to chisel out the corners where the router won’t reach. If anyone knows a better way I’d love to hear it.  It would obviously be preferable to make a new jamb but he wants to keep the cost down. Thanks in advance!
Jencar
  1. calvin | Feb 13, 2015 01:23pm | #1
    Welcome back
    A steady hand and a multimaster would work.  Pare as necessary with your chisel.  Clean up the transition with the sanding feature.
    1. Jencar | Feb 13, 2015 03:39pm | #2
      LOL
      I went to look at the door he bought, it's also 3 inches too short, so he's gonna look for another door and this time take the measurements I gave him .  Is a Multimaster something like a Dremel? I may have to invest in one!  Thank you
      1. calvin | Feb 13, 2015 05:46pm | #4
        LOL twice.
        last year was the year of the door.  I hung, set, installed, trimmed, added to, etc.  Many times owner supplied "used" parts.  Certainly wasn't boring.
        Multimaster is a Fein multi tool.  Oscillating triangle sander- cutting tool.  Bosch, PC, dremel, Festool, to Harbor Freight offer it now.   Many yrs ago when it was a one of, I got one and found it excellent with only your skill and imagination to limit its use.
        1. Jencar | Feb 13, 2015 09:44pm | #5
          Dorz
          When I worked for a door/window place in Santa Monica, their estimater drove me crazy...ordered a door that was 2 inches too short, a prehung door that was 3/8 too wide for the rough opening so I cut down the jamb and door and rehung it; a fairly expensive prehung oak entry door that he forgot to account for the tile floor inside so I cut an inch off the door, pull off the sill and cut the legs of the jamb; cut mortises for mortise locks by hand,  I agree it was not boring. I was the queen or door hangers for a while.
          Thanks again! take care, Jen
    2. Jencar | Feb 13, 2015 03:42pm | #3
      LOL
      Oops posted this twice
    3. DanH | Feb 13, 2015 09:54pm | #6
      Yeah, I immediately thought of using a MultiMaster.  I'd use a router for the bulk of the work, and the MM for the ends.  Ideally leave the stops a bit fat and then pair down with a chisel, though, since the MM cut isn't incredibly smooth, and it tricky to get a straight cut.
      1. Jencar | Feb 13, 2015 10:00pm | #7
        Trimming down doorstop
        Dan,  my old motto: "it's better than it was" my new motto "I can do it, but it might not be pretty"
        Thanks!
Picture-Perfect Pergola
