For both the sliders and the casements I plan on gluing and screwing a sill extension onto the existing sill and then adding the rest of the trim. Is this how the sill should be added?
I have some Marvin casement and slider windows to trim out. I’ve trimmed other windows but not ones that already have a sill. I want to add a sill and I want to make sure the way I am doing it is the right way.
Upgrading the footings and columns that support a girder beam is an opportunity to level out the floor above.
Short answer is yes.
What you have are jamb extensions. I might not try to flush up the sill to the bottom extension. A slight reveal should bother no one.
If both sash slide, you have the option of biscuits and clamps so no plugs for screws. Same with the casements.
