Trimming out a stairwell
law3 | Posted in Construction Techniques on December 1, 2004 07:43am
I need to trim out a stairwell going down to a basement.  The stairs are site-built, U-shaped with a landing in the middle.  The builder used OSB for treads and risers and left it short of the drywall walls by about an inch on both sides (the stringers are not against the wall studs).  The stairs will be carpeted.
Any suggested reading on stair trimming basics? Books or articles.
Should the OSB stay?
Thanks for any advise.
Edited 12/1/2004 12:04 am ET by law3
  1. zendo | Dec 01, 2004 02:19pm | #1
    just a thought, I think that the framer left the stringers shy so that you could fit a skirt board on each side Skirt against wall then finish tread and riser would have made the difference.  As for the treads you can check the height, if correct it should measure equal on each step finish floor to finish floor.  If it seems off, (low) it may need another layer on it well glued with liquid nails (or other like it) and nailed well.  But the osb's were probably temp treads and if you want 2x's you can rip them off or leave them and add...also shim level.
    I dont have correct titles but there are a few good books, one Taunton, and the other is Stairs and balusters or something you can find on amazon search.
    Edited 12/1/2004 6:21 am ET by zendo
  2. MojoMan | Dec 01, 2004 06:48pm | #2
    The current issue of FHB has a good article on finishing stairs.
    Al Mollitor, Sharon MA
    1. zendo | Dec 01, 2004 08:27pm | #3
      yes thats true... thats where I saw that.
  3. Piffin | Dec 01, 2004 08:58pm | #4
    That sounds like the way I do site builts.
    You can set the trim riser against the walls by cutting angle at top and bottom without needing to notch over each step.
    Then you fit individual treads and risers> I don't do carpet on stairs, but you can probably use baarf board treads cheaper than solid lumber since it will be covered. For thicknes, keep depth of carpet in mind.
    1. zendo | Dec 01, 2004 09:24pm | #5
      If you havant seen it, take a check at my paint sub thread... comment when you have time.  I'm in Maine thats why Im asking.  Sorry for all the messages I left one for you there in suggestion of another reader.
      1. Piffin | Dec 01, 2004 10:25pm | #6
        Can you post a link to it?
  4. JRuss | Dec 02, 2004 01:56am | #7
    The space is for a skirt board. Or you could run a waincot with 3/4".
    Never serious, but always right.
