Howdy, I’m having my windows replaced with vinyl units (I’m an architect and can’t afford wood), and I have decided to trim the interior myself. I have two questions. First, I like the look of vertical grain douglas fir, but it’s real pricey. Can anyone recomend an alternative? Second, with vinyl frames, should I place the wood trim tight to the vinyl, or leave a gap (1/4″?) and fill with sealant? Thanks!
Tips for protecting your personal information when using Wi-Fi-connected devices.
tight
Where are you that you would consider DF expensive?
Tight fit if you will.
I'm in Boulder, Colorado.
If you're fomr Boulder - Any chance you've heard of this?
http://www.postindependent.com/apps/pbcs.dll/article?AID=/20031117/VALLEYNEWS/31116001
I'm thinking it's fairly close to there...I'll do anything for money, except work.
that's on the other side of the state, about 3 hours drive (5 or 6 during winter).
What were you considering or DF? 1 by? Mouldings? Which grade? Clear verticle?
Might be your source...
i was thinking of clear vertical grain, 1x, sort of a craftsman bungalow style, until i started pricing CVG doug fir....
I see you've got IMERC on the case... that pretty much ought to take care of it.Kevin Halliburton
It has come to my attention that some of you mistook my comment as a rip on IMERC. Not a chance! I meant what I said in all sincerity and frankly have no wish to die. :-)>
Truthfully IMERC, I wish you lived a little closer so I could abuse your generosity and significant connections a little more often. :-)>
Ah-pree-shate-cha! No offense intended.
(Geez, I gotta get a new reputation around here)Kevin Halliburton
What did you come with for a BF price? You pricing out of Denver?
Can you do a certain amount of milling on your own? (handle rough sawn)
local prices are around $7/b.f., but i will keep looking.
Thanks!
I'm down the street from you. (west of the Springs)
2 to 2.2$ bf / s4s.
67 to 87 cents bf rough sawn.
That's why I asked. I don't think D and C pine go that high.
Well, there ya go... did I tell you the man would come through or did I tell you the man would come through?!
I have to laugh at the concept that you are just down the street from anybody though. If Rich is gonna run out and pick this up at your place you might want to see if he needs it before the snow starts melting around there next summer. :-)>Kevin Halliburton
I'm just down the street from Hasbeen but not Andy C...
Thanks - I'll start wearing our my phone dialing finger! I can't wait to start using the new finish nailer I got for my birthday!
Rich,
I'm going to be doing the same on my house next year and I'm looking for the craftsman look as well. I think the most cost effective way to trim out the windows would be red oak for stain grade and poplar for the painted stuff.
I don't know about availability in your area, but a good alternative to VG DF is VG Western Hemlock. In my area it's about 2/3rds the cost of Doug Fir and I've used it quite often for the very application you describe. It's also available in a lot of moulding profiles.
It has a slightly different color than DF, but playing with some stains can get you there.
As others have advised, install it tight.
