tripped breaker
mandingo751 | Posted in General Discussion on July 21, 2007 01:03am
Help.I’m not an electrician so take it easy on me if this is an easy one.I came home today flipped on the kitchen light bam! tripped the breaker.I tried to reset and it won’t.So I unhooked the light fixture, still won’t reset.Did the breaker fry,If so why it’s only 2 years old?
  1. JTC1 | Jul 21, 2007 01:21am | #1
    >>I tried to reset and it won't.<<  Generally indicates either a bad breaker or a dead short somewhere in this circuit.
    >>So I unhooked the light fixture, still won't reset.<<  Tells you that this light fixture is not the problem.  Look elsewhere in the circuit - I would be looking in the switch box which houses the switch for this light, since the circuit was on until you flipped this switch. Look for evidence of arcing - burn marks, smoke trails, welding spatter, etc.
    >>Did the breaker fry,If so why it's only 2 years old?<< Breaker could be bad. Can be bad right out of the box, and occasionally they just decide to die prematurely.
    Go slow, look around - could take a while.
    Others will chime in soon.
    Jim
    Edited 7/20/2007 6:22 pm ET by JTC1
  2. mandingo751 | Jul 21, 2007 01:31am | #2
    Just realized that a bulb blew in the above mentioned fixture.This has happened before,but the breaker always reset.Could the fixture fry the breaker?
    Edited 7/20/2007 6:32 pm ET by mandingo751
    1. JTC1 | Jul 21, 2007 01:48am | #3
      >>Could the fixture fry the breaker?<< Stranger things have happened.
      Check the fixture before re-installing with a continuity meter.  There should be no continuity between the hot side and neutral or the housing.  No bulb in fixture for test 1.
      Insert new bulb and retest, assuming incandescent you should now have continuity between hot and neutral leads; no continuity between hot and housing.
      If all is OK with the fixture --- the road points toward the switch box and then to the breaker itself.
      Jim
      1. mandingo751 | Jul 21, 2007 01:52am | #4
        Thanks, I will see what I can do.
  3. DanH | Jul 21, 2007 01:54am | #5
    Most common cause of this is a bulb that blows, and, in doing so, shorts internally. If this happens, the breaker should reset when the wall switch is off, but may trip again when the switch is turned on.
    If the breaker won't reset with the wall switch off, check for some other bulb on the same breaker. Failing that it COULD be a bad breaker, but also could be bad wiring somewhere (and the first place to suspect is in the wiring around first switch you flipped, especially if it's always seemed a little loose).
  4. LeeLamb | Jul 21, 2007 02:03am | #6
    When many breakers trip you must flip them to the off position even though they are tripped.
    Identify tripped breaker
    Flip it to the off position
    Snap it quickly "on"
    Many breakers will not allow you to simply reset from tripped.
    Good luck, be careful.
  5. mandingo751 | Jul 21, 2007 02:34am | #7
    I just changed the breaker out with a new one.It didn't trip but, I haven't reconnected the suspect light yet.I dont have a continuity  tester. So I don't know If I should reconnect or 86 it.
    1. DanH | Jul 21, 2007 03:20am | #8
      Get a known good flashlight battery. Hold the white wire of the fixture on the negative end of the battery and tap the black wire against the positive terminal. If you don't see any sparks (check the battery with a straight piece of wire to know what to look for) then the fixture isn't shorted.
      1. mandingo751 | Jul 21, 2007 03:31am | #9
        I'm confused no spark means short or no short?
        1. DanH | Jul 21, 2007 03:34am | #10
          No spark is good -- it means there's no short. But also try using a single piece of wire from one terminal to the other so you can verify that the battery is good and see what a "bad" spark would look like.
          1. mandingo751 | Jul 21, 2007 03:37am | #11
            Brilliant! Thanks Dan
Townhouse Transformation
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
