Trowel size and grout width for 18″ Tile
littlehenry | Posted in Construction Techniques on September 30, 2006 04:01am
I will be laying some 18″x18″x1/4″ ceramic tile. What is the recomended trowel notch size and grout spacing for tile of this size? It will be going over a 3/4″ wood subfloor with 1/2″ hardie backer attached.
    ToolFreakBlue | Sep 30, 2006 04:31pm | #1
    per Michael Byrne in Setting Tile, pg 141:" ... deep U-notched trowels are used for large tiles (12 in, and up)..."
    just before that he says "Genrerally speaking, 1/8-in. to 3/16-in, V-notched trowels are used for thin tiles (glazed wall tiles for example), 1/4in. square-notched trowels are used for larger tiles (6-in. to 8-in. floor tiles, for example) and..."
    The package would have recommended sizes too.
    TFB (Bill)
    Heck | Sep 30, 2006 05:43pm | #2
    Usually 1/4 x 1/4 for tile that size.
    Use a trowel that size, set one tile, then pull it up again. This will tell you if you have too much/too little thinset. The thinset mix will have to be not too runny or too dry.
    Mix your thinset the same from batch to batch.
    Grout joints can be whatever you like, the current trend is to small grout joints - I would use 1/4" or smaller myself.
    Use modified thinsets and grouts.
    _______________________________________________________________
    objects in mirror may appear behind you
