Truck ac problem.
Gunner | Posted in Tools for Home Building on August 1, 2008 02:16am
    The ac in my 97 Ford work truck comes and goes. It seems to go away the hotter it get outside. But it will come back. I don’t think it’s low on freon because it will get cold and stay that way for some time. But eventually it will start blowing warm air. Occasionaly it will return to blowing cold air but it doesn’t last long.
   Anyone have a clue?
I’m moving to the country, I’m gonna eat a lot of Peaches. Aug. 8,9,10th Follow me.
http://www.youtube.com/watch?v=19McuaPKjI8
  1. ChicagoMike | Aug 01, 2008 02:28pm | #1
    Sounds like the switch for the compressor. When it doesn't work and the a/c is on, check to see if the line is cold. Be careful, the other line will be HOT.
    "It is what it is."
  2. USAnigel | Aug 01, 2008 03:55pm | #2
    Check the clearance on the compressior clutch, mine did the same thing. I removed the center bolt and a shim to reduce the clearance and its all good (35k since) Takes five mins to do.
    BillHartmann | Aug 01, 2008 04:06pm | #3
    Mine turned out to be a bad thermostatic fan and thermostat causing the engine to get hot, but not overheat.
    http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=104720.1&search=y
  4. dvs | Aug 01, 2008 06:09pm | #4
    I had a Chevy S-10, did the same thing. I took it for repair and figured anytime they work on A/C it's going to cost a bundle. Turned out to be a bad vacuum line on the dash control switch. If I remember correctly it cost about $17.
    IMERC | Aug 01, 2008 07:15pm | #5
    the wire connector on the switch on the compressor...
    wiggle it while call for AC and see if the compressor kicks in and out...
    WOW!!! What a Ride!
    McDesign | Aug 02, 2008 01:46am | #6
    Maybe the condensate drain is clogged and the condenser is freezing up?
      BillHartmann | Aug 02, 2008 02:12am | #7
      "Maybe the condensate drain is clogged and the condenser is freezing up?"First of all never heard of a condenser freezing up. I am guessing that you ment evaporator.But I don't know why a clogged condensate drain would cause the evaporator to freeze up.
        McDesign | Aug 02, 2008 03:01am | #14
        Whoops - one o' them rad-I-ator thangs - happened in DW's first minivan from her folks - lots of leaves and stuff inside the airbox - it would drain, but slowly and after the car was off for a while.
        Humid here!
  7. User avater
    Gunner | Aug 02, 2008 02:29am | #8
       Thank guys. I had a three hour drive home today and it seems like it's fine as long as I'm up to highway speed. I got stuck in slow moving traffic a few times on the interstate and it would get warm. After kicking it back up to 65 for a brief time it would get ice cold again. It did take a a minute or two at least after slowing down for it to turn warm. That's what I seemed to notice anyway.
      I'm gonna try the ideas above. Thanks.
    I'm moving to the country, I'm gonna eat a lot of Peaches. Aug. 8,9,10th Follow me.
    1. AllenB | Aug 02, 2008 02:45am | #11
      It could be the blower door.  It breaks and swings free instead of opening and closing with the motor.  It swings open when you take off and swings closed when you hit the brakes to slow down.  Sometimes you can hear it thump back and forth.  Basically when the door swings the wrong way you are heating instead of cooling your cab.
        Gunner | Aug 02, 2008 02:52am | #12
            Good idea. Where do I locate that puppy?
        1. AllenB | Aug 02, 2008 03:24am | #15
          It's under your dash and its an expensive repair.  I couldn't begin to figure out how to get at it so I took it to the dealer.
            Gunner | Aug 02, 2008 04:42am | #16
                Thanks.
    2. john7g | Aug 02, 2008 03:43pm | #17
      have you got the wiring diagrams for the truck?  That's how I learned about high eng temp disabling the AC. Does the compressor still turn or does it disengage when the problems occurs?
        Gunner | Aug 02, 2008 03:48pm | #18
           I don't have the diagrams. I'm not sure about the compressor. Next time I'm idling and it happens I'll look.
  8. danski0224 | Aug 02, 2008 02:39am | #9
    I bet it is low on charge.
    Quick connect line fittings used are notorious for leaks.
      Gunner | Aug 02, 2008 02:41am | #10
         When it's blowing cold it's cold though.
      1. danski0224 | Aug 02, 2008 02:57am | #13
        Just a guess, really.
        The compressor is ultimately controlled by the computer in newer vehicles... could be something simple or not so simple.
        Newer variable displacement compressors can make troubleshooting difficult. There should be a troubleshooting chart available that should help with the timing of compressor clutch cycling- for a start.
        The only real way to make sure the charge is right is to evacuate and weigh in the correct amount of refrigerant.
        If there hasn't been any work done to it since 1997, a leak is a reasonable guess- especially in a Ford.
        Check the quick connect fittings for oily residue.
        Compressor shaft seals leak all the time.
        Check compressor clutch clearance as previously mentioned.
  9. USAnigel | Aug 04, 2008 09:20pm | #19
    Hi Gunner, You have lots of things to look at. Let us know what the problem turns out to be.
      Gunner | Aug 05, 2008 02:47am | #20
         I will. I drove up to Middletown Ohio today. Bout 3 1/2 hours. Worked like a champ. When I got to town and got into traffic it started acting up. I'm kind of wondering if it's not Vac related.
      1. john7g | Aug 05, 2008 03:04am | #21
        eng temps go up when you're in traffic.  might be enough to break the threshold of the switch.  Eng could be running warm, switch could be opening too low.  Maybe
        Edited 8/4/2008 8:04 pm ET by john7g
          Gunner | Aug 05, 2008 03:50am | #23
             That's an idea.
            Dreamcatcher | Sep 04, 2008 03:05am | #24
            did you ever figure out what was wrong with your van? I have the same van and the same problem! AND my ABS keeps going out for no reason.And the armrest in the door hurts my elbow.anyway, about that AC.......?gk
            Gunner | Sep 04, 2008 04:26am | #25
               I've got a truck. I"m thinking it's just low on Freon. A guy who had that problem before was riding with me week before last. He shut the ac off when it started it, and then turned it back on after a few minutes. It worked good for the most part. He said that if it's low on freon it will freeze up. Makes sense I guess. I'm not a hundred percent sure. I need to get it dropped off and looked at in the next couple of weeks though. Jus tin time to not need it. LOL
              http://www.youtube.com/watch?v=-sbqIyeed4g&feature=related
          3. Oak River Mike | Sep 07, 2008 03:29am | #26
            It can also be the expansion valve or the receiverdryer.  Try adding some refrigerant first as thats the easiest and least costly as long as its R134a and not R12.  The other two items are a bit pricer but if you have the tools, you can still do them yourself.
            Gunner | Sep 07, 2008 05:14am | #27
               I think we are having a slow week this coming week. If that's the case then I'll drop it off at the shop and finaly get to the bottom of the deal.
            Sphere | Sep 07, 2008 06:52am | #28
            I hadda put in a new AC in the van a few weeks ago, the drier was only 36.oo but I didn't need it, it was the comp that hurt.
            GMC Vs Ford? I dunno, but the drier is probably not too exp.Spheramid Enterprises Architectural Woodworks
            The world of people goes up and
            down and people go up and down with
            their world; warriors have no business
            following the ups and downs of their
            fellow men.
          6. Oak River Mike | Sep 07, 2008 04:43pm | #29
            Sphere,
            Its good practice to almost always change the receiver dryer when the system is opened up as the dessicant (sp?) in it will draw moisture from the air while the system is open.  Usually if you change the compressor or even a broken AC line, they suggest changing the receiverdryer.
            Mike
          7. User avater
            Sphere | Sep 07, 2008 04:59pm | #30
            Ooops, well, it was a GM dealer that installed the new comp, and he said I didn't need the drier. Maybe cuz we ain't quite as humid as yall down there in the swamp lands.
            Either way, I gots plenty cold air, I didn't WANT air, just my serp belt to not get trashed when the comp. froze up.
            The brainiac that thought up those should be castrated and fed the neuticles, I mean, run every THING offa ONE belt? What the hell kinda plan was that?Spheramid Enterprises Architectural Woodworks
            fellow men.
          8. USAnigel | Sep 07, 2008 05:15pm | #31
            Its all about assembly time. 4 belts in the old days took 3 times longer to install and no auto tensioning. My 2005 GM van still has 2 belts!
          9. john7g | Sep 07, 2008 05:31pm | #32
            Hopefully GM is warrantying it.  I was taught that any time you open the system that the rec/dryer get's changed.  It's also a filter for any other contaminants that may be inthe system, from trash that slips in when the system is open to debris from a wearing/failing compressor.
  10. Hudson Valley Carpenter | Aug 05, 2008 03:10am | #22
    Ford engineer becomes lost in the Mojave desert.  When found, several days later, he's carrying a car door.
    Asked what the door is for he replies, "Well, when it gets real hot, I roll down the window."
    F.O.R.D.: Fix or repair daily
    Edited 8/4/2008 8:13 pm by Hudson Valley Carpenter
Picture-Perfect Pergola
