truck cap sill
rez | Posted in General Discussion on October 26, 2002 01:30am
Putting a topper cap on the bed of the truck. Was wondering what you’all recommend as a sill liner to keep water from creeping in along the seam?
 Let the thunder crack and the waves roar.
 We’re going on.
  1. sdr25 | Oct 26, 2002 04:33pm | #1
    What I do is go to the local truck cap supplier/installer and purchase a roll of the foam tape they use. It's about 2" wide. Can't remember how much they get for the stuff.
    Scott R.
    1. maneyj | Oct 27, 2002 01:13am | #2
      I use a couple of strips of foam pipe insulation split in half.  I glue it to the cap only.  It works great
      1. GregGibson | Oct 28, 2002 05:22pm | #3
        Rez,  If you don't have an over-the-rim bedliner, there's someone out there that markets a rubber seal with a magnetic bottom.  slaps right onto the top rail of the bed and stays in place for the camper top.
        Maybe JCWhitney.com.
        Greg.
  2. jc21 | Oct 28, 2002 07:28pm | #4
    I got a new cap last month and they used foam tape like Scott described. They had to double it in a couple of places because of the bedliner- its under the rail at the sides and over at the front of the bed. Works fine .......... stays dry inside.
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
