try again rafter cable ties
paulmars | Posted in Construction Techniques on May 14, 2014 07:59am
I’ve decided to add rafter ties to my home. Im thinking of using cable.
1952 house. This house was built with NO rafter ties and very few collar ties. The joists run from gable to gable. Ridge is not sagging, walls are not bowing. However, I have added hurricane straps and gable supports. Soon, i will be replacing the roof and while at it, screwing the roof planking to the rafters. Im making my home as hurricane resistant as possible.
Therefor I have also decided to add cable rafter ties and 2×6 collar ties.
I need advice.
pa
  1. AndyEngel | May 15, 2014 01:38pm | #1
    I'd say you need advice from an engineer. The execution shouldn't be hard, but knowing the specs is another issue. Contact a structural engineer.
