tub recaulking project goes south
Kimball_house | Posted in General Discussion on January 1, 2009 01:51am
Decided to replace perimeter sealant in a tub with a tile surround.  Was going well using mechanical removal.  Then I decided to clean up the residue with a chemical caulk removal product called ‘Motsenbocker’s Lift Off’ purchased at HD.  The liquid product ran from the point of application and now I have a faint discolored caulk residue on the perimeter surround of the tub.  Looks pretty bad.
This residue is tenacious.  Have tried isopropyl alcohol, ammonium cleaner (409), vinegar, and a spray contractors’ solvent (De-Solv-It) with little success.  Spot reapplication of ‘Lift Off’ softens the residue somewhat, but just enough that fairly vigorous scraping with a steel scraper will dislodge.  This is very tedious and I fear I will trash the finish if I have to pursue this approach.
Tub is a jetted acrylic Kohler Portrait tub.
Any suggestions appreciated.
    BillHartmann | Jan 01, 2009 02:06am | #1
    I have used LiftOff several times, but never had that problem.
    Try damping some cloth rag with it and then rubbing.
    1. jrnbj | Jan 01, 2009 05:24am | #5
      So, what's da best cakin fer tube joints dese days?
        BillHartmann | Jan 01, 2009 06:46am | #6
        I like the GE Type II silicone.And I use rubbing alcohol for tooling the joint..
  2. jej | Jan 01, 2009 02:10am | #2
    could you fan the new caulking out to cover the discoloration
    EricPaulson | Jan 01, 2009 02:28am | #3
    Try acetone or laquer thinner. The finish on that tub should not be damaged from either product.
    But test it first.
      IMERC | Jan 01, 2009 02:57am | #4
      add denatured alcohol and paint thinner to the list before the Lacquer thinner or acetone...
      of course, test 1st...
